Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Desperately need help with cooling fan
Old Mar 31, 2024 | 06:44 PM
jmoney6's Avatar
Default Desperately need help with cooling fan
Hi all, I’ve been at this all afternoon and have hit a brick wall.
2010 8th gen Civic EX R18 motor auto tranny
when I put the key in the ignition the drivers side engine cooling game stays on until I remove the key.
Ive replaced all the fan relays under the hood. Coolant flush OEM Honda thermostat
both upper and lower ETC sensors with know good parts.
I grabbed freeze frame data and the ETC is showing -40
the Temp gauge on the dash as far as I can tell is behaving normally as it should.
i live in S. Florida so it’s not the end of the world but I really really want to get this solved ASAP.
ECU may be the next move however that pretty invasive.
im also going to check for continuity at the ECU perhaps there’s a short somewhere.
please please please. What else can I try?
from what I can tell now the AC fan behaves like it should. Goes on and off normally and only ever turns on when the compressor is calling for cooling.
Royhill
Feb 23, 2021 01:45 PM
skyeboy
17
May 18, 2013 07:15 PM
saikou
Sep 26, 2012 10:41 PM
technine
Mar 19, 2009 04:12 PM
BK101
Jul 31, 2001 05:19 PM
