BillsVTEC New Member
Hi, my name is Bill and I own a 1973 Lotus Europa with a 1998 Integra GSR VTEC motor. Glad to be a member of this group and looking forward to connecting with some Honda lovers.
Welcome to the forum Bill. Is this a running and driving car ? You have a very interesting chassis/engine combination... I would love to see detailed pics of what you have !!! I have a 1974 Europa chassis that I was considering dropping a K24 into and there are going to be obvious interference issues with the chassis in the "waist" of the frame... up near the cockpit. How did you solve this ?
I am not sure if there is a minimum post count required before you can send Private Messages or create a post in the General Forum... but it may be 5 or 10 posts.
I didn't build the car but it is so cool I would love to show it to you but I couldn't get the reply to post the photos. Do you know how to attache the phohe car isn't running right now. (Fuel injection problem). I tested the injector harness with noid light and out shows a pulse but the injectors are not firing. I'v tested the injectors and the fuel rail and pump and the are receiving fuel. I have power to the injectors showing12.4 volts and 9.4 when cranking.
Just can't figure out why they don't wire. Could the ground signal coming from the ECU be strong enough to light the noid light but not the injectors?
If you have any ideas let me know.
Would love to see some of you pics. Thanks, Bill
