help 2002 honda 2.3 Engine Management and Tuning help
Old Mar 20, 2024 | 11:42 AM
Filekidb's Avatar
Default help 2002 honda 2.3 Engine Management and Tuning help
2002 honda accord 2.3l v-tech,
Quick background, was trying to repark my vehicle closer to the one infront of me...................
Requires to start your vehicle and go, so as I was trying to start my vehicle and as it was half way into like any common cranking and motor reviving start as suddenly before completely being started it came to a spudder end. I thought maybe i let off the key to soon!? Cause Why would it not start? as it seemd what else could it have been?
thats just my thought as trying to diagnose the problem, but now after many things
1)HAS SPARK
2)HAS FUEL
3) NEW FUEL PUMP AND ASSEMBLY
4) NEW MAIN RELAY
5)CHECKED ALL FUSES 3 TIMES AND RELAYS
6) NEW KEY AND SYNCED IMMBOLIZER AND IGNITION SWITCH AND ECU......ECU HAD WHAT APPEARED OIL IN ONLY ONE OF THE MAINHARNESS CONNECTOS., BLUE - CONNECTOR C PINS 11-31 POSSIPLE SHORTAGE DUE FROM WHAT APPEARS OIL (WHY I REPLACED ECU)
****NOTE WITHOUT THE MAIN COMPUTER CRANKING SOUNDS THE SAME HYPER ALSMOST LIKE NO LOAD
**NOTE STARTING NOISE NEVER HAS SOUNDED LIKE A NO LOAD, HYPER FAST WINE CRANK SOUND.......NO COMPRESSION SOUND?
**** AIR INTAKE IS BLOWING AIR OUT, CANNOT SPRAY ENGINE STARTER FLUID THRU AIR INTAKE, BLOWS BACK
7) CHECKING TIMING BELT FOR FAILURE AS REASON WHY VALVE APPEAR STUCK FOR THE NO COMPRESSION SOUND AND EXOLINATION FOR BLOWBACK....
*** HAVE VALVE COVER OFF, TOP TIMING COVER EXPOSED SHOWING THAT BELT STILL TURNING VALVES OPEN AND CLOSED
TOP DEAD CENTER WHAT POSITIONS WILL EACH CYLINDER BE IN AND WHAT CORRESPONDING VLAVE POSITIONS SHOULD BE IF TDC WAS CORRECT???
GETTING COMPRESSION GUAGE TODAY, BESIDES ALL THIS
YOUR THOUGHTS, WHAT DO YOU THINK OF THIS?
Old Mar 20, 2024 | 12:59 PM
DVDr's Avatar
Default Re: help 2002 honda 2.3 Engine Management and Tuning help
Are you running a completely stock ECU ? Has it been flashed.
Do you have any check engine lights.
#1 thing I would do is a get an OBD reader and scan ecu to see if there is any faults.
Old Mar 20, 2024 | 07:23 PM
Filekidb's Avatar
whats that? cute, no, no codes that would have cause these symptoms. but again how much do you trust a obd2 that information your requesting from is probably shorted out. that C connector appears to have oil in it. and there looks like while trying to crank it i lost all my oil days ago, maybe thats when that happen but who knows maybe not, my obd2 had no pending codes or codes currently that i can pin point,, however i can tell u that lasst codes i fixed weather it have been months years weeks or days i dont remember when how far back these were fixed prior to this. there was
p1519 p1753 p0700 p1166
***ITS CLEAR AS DAY THAT THE TIMING IS FUCKED***
Thank you for atleast responding
Filekidb
Mar 20, 2024 11:38 AM
Munkeyjdm86
Feb 4, 2014 07:21 AM
jooanyenna
Jan 5, 2014 10:27 PM
jweeks
Jul 14, 2008 04:35 PM
erniecombs
Sep 26, 2007 06:21 AM
