Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Need help!! Fans not working unless jumped or A/C on (only for 1 minute)
Old Mar 20, 2024 | 07:06 AM
bladeserpent's Avatar
Default Need help!! Fans not working unless jumped or A/C on (only for 1 minute)
Hi all,
I have read over and over again almost a hundred forums and I just can't figure this problem out. I have checked and change everything people have mentioned. 2002 Honda Civic EX Coupe.
I changed thermostat twice, coolant fan switch off the radiator hose 3 times, ect sensor twice, new fan, known relays (even bought new ones and tested with other relay slots like horn), all fuses are good, bled the coolant multiple times for over hours. Idk what the problem is. The fans DO work when I hit the A/C on or jump with a paper clip at the coolant switch coming off the thermostat housing. Problem too is when I hit the A/C button and the fans turn on, it only stays on for about a minute. Is it maybe a wiring issue?? Ground issue?
Any help would be super appreciated!! Thanks in advance.
Mike1971
24
Jun 1, 2016 06:01 PM
crazyjetsfan22
18
Oct 17, 2010 08:01 PM
NickyB92HCivic
Oct 17, 2010 10:49 AM
landon.alder
14
Aug 6, 2009 02:53 PM
EG2ENVY
16
Mar 2, 2009 12:41 AM
