S300, CEL no fuel prime.
Old Mar 12, 2024 | 03:27 PM
Tyler_Davis0513's Avatar
Default S300, CEL no fuel prime.
Hi, I have a I believe p28 S300 ecu. It worked fine just yesterday but I come to start my car and I get hit with a cel and no fuel pump prime. So I jumped the fuel pump and it fired right up no issue. What could be the cause of this what can I do to fix it?
Old Mar 12, 2024 | 09:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: S300, CEL no fuel prime.
Your fuel pump circuit is damaged... to start, you need to have your capacitors replaced right away. This MAY fix things, but it may not. You may have other problems within the fuel pump circuit that will require additional repair.
Old Mar 12, 2024 | 09:21 PM
as for the circuit you mean the one in the ecu itself or my actual car?
Old Mar 13, 2024 | 08:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
In the ECU. Your chassis is likely fine as far as the wiring goes... unless you have altered/modified it prior to this issue occurring.
Crysix
Apr 19, 2026 06:21 PM
cticknor666
Apr 2, 2011 05:23 AM
bravoecho11
Apr 26, 2005 06:44 AM
_jester_
Jan 28, 2005 03:59 AM
