Suspension & Brakes Theory, alignment, spring rates....
Coilover compatibility
Old Mar 8, 2024 | 07:25 PM
Hondamack's Avatar
Default Coilover compatibility
Hey I was wondering if any one had knowledge about compatability between suspension on sub models like will ek coilover fit ex of the same year
Old Mar 8, 2024 | 09:06 PM
BACustoms's Avatar
Default Re: Coilover compatibility
Yes, eg, dc, and ek are normally very interchange able. Basically all 92-00 civics and 94-01 integra’s. Aftermarket stuff is especially interchangeable. But yes, if you had a 99-00 Si for example and wanted to put coil overs on a base model, it would work.
Old Mar 9, 2024 | 09:20 AM
Hondamack's Avatar
Thanks I figured it out. I guess the ej models are the coups I broke the bolt that holds the back strut on. Was going to try and put lowering springs. But forgot what a pain they can be to dismantle. So I just bought a mediocre set of coil overs and was having trubble figuring out what was compatible. I appreciate your response
Old Mar 10, 2024 | 07:04 AM
NVturbo's Avatar
O.G. triple O.G.
Coillovers are interchangeable for Civics 88-00. For the 96-00 models, the rear LCA are thinner at the 2nd mounting bushing/mounting hole. That is why many reputable coilover companies will supply spacers to accommodate for the gap.
Hondamack
Mar 10, 2024 05:47 AM
jrodc5
Nov 20, 2012 01:23 PM
koon74
Feb 10, 2007 07:43 PM
