engine won’t stay running.
Old Mar 8, 2024 | 10:05 AM
emixoo__'s Avatar
Default engine won’t stay running.
helloooo. i’ve been engine/manual swapping my eg with a d15b7, s20 trans. a few months ago i found out the timing was off, just got done replacing water pump/ tensioner pulley/ belts and lining up marks etcs. i swapped the manual intake manifold with the auto one because the car still seemed to run super boggy and would die (auto one was way cleaner inside) everything seems to line up with all the sensors. i have a new fuel pump and fuel filter, replaced my distributor and haven’t been able to ignition time it yet because the engine still can’t seem to run right. it’ll actually start and idle around 1 rpm’s and then die after a few mins. what’s my issue i need helpppp.
SlavaEK15
12
Feb 17, 2020 08:19 PM
Moab Man
Nov 15, 2012 01:28 PM
Rob Dizzle
Apr 23, 2003 02:51 PM
