B16 - Rotating Crank while CAMS at TDC
Old Mar 3, 2024 | 05:19 PM
Grade50's Avatar
10 Year Member
Default B16 - Rotating Crank while CAMS at TDC
With the timing belt REMOVED and the CAMs are set at TDC, can the crankshaft be fully rotated without any valves interfering with pistons? B16a2
While I dont think i'll have to go there, it would be good to know for an upcoming timing belt change.
Old Mar 3, 2024 | 07:28 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: B16 - Rotating Crank while CAMS at TDC
You will definitely bend valves. Cyl 1 and 4 will be fine, but 2 & 3 will have valves open too far.
Old Mar 4, 2024 | 06:39 PM
Grade50's Avatar
10 Year Member
Thank you. I'm sure I would feel them before bending a valve, but still it seems like it could be easy to get lost if anything is rotated withe the belt off.
On other non-hondas iv'e done timing belts on, the cams are set to a non-TDC "service" position before the timing belt is removed, and which that lets you rotate the crank freely to any position.
Old Mar 5, 2024 | 01:33 PM
spAdam's Avatar
Loved
Community Favorite
Back off the valve adjustment screws if you are unsure. Solves the problem, and you probably needed to adjust your valves while you had the cover off anyway.
Old Mar 6, 2024 | 07:11 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Or pull the cams, eh? Then all the valves are closed?
by39
Jan 1, 2023 10:36 AM
Mjalaly
Jun 26, 2015 10:56 AM
lakahang
Jan 21, 2010 09:47 AM
Jeffrey9
Aug 6, 2008 09:25 AM
91 ZC hatchback
Feb 27, 2006 10:52 AM
