Issue with wiring 1993 del sol S no bulb check circuit no beeper
I have a del sol with a B18 swap almost completed, my attention has started to turn to the instrument cluster and I noticed that when turning the key there is no bulb check, and no beeping for the door open. Checking the haynes wiring diagram I tried to clean ground K, bot nothing changed.
i will note that the a/c backlight does turn on and changes in response to the dimmer
DelSolMike
May 28, 2014 07:28 PM
spcrxracer
Sep 3, 2004 09:11 AM
davidthongnguyen
Jul 30, 2003 05:12 AM
