Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2007 Ridgeline codes p0171 & p0174
Old Feb 23, 2024 | 05:47 AM
Kodyt58's Avatar
Default 2007 Ridgeline codes p0171 & p0174
Hello,
Ok I've been chasing the lovely lean codes for a while now and have now come to the end of my knowledge on what to do ( without taking apart the motor ).
At first I had random misfires and an evap system codes, did a valve adjustment that cleared the misfires, and swapped out the charcoal filter and that fixed the evap code.
I put new spark plugs in, and new valve cover gaskets and also new spark plug well gaskets. everything was looking good and then the lean codes popped up.
I checked for air leaks. didn't see anything, I swapped out all new fuel injectors (factory), all new intake manifold gaskets and plenum gaskets, new purge valve, maf sensor, pcv ( all factory ), new egr, O2 sensors, cat's and exhaust gaskets.
Took it to my local mechanic, only thing he could see was maybe the timing belt, so I did the whole kit, belt, water pump, pullies and tensioner. then I had my mechanic do a valve adjustment.
The engine runs slightly rough at cold start but then is starts and runs fine when its warm, not sure what to do at this point besides opening her up.
what would be your suggestion on my situation at this time?
Old Jan 4, 2025 | 04:04 PM
tlkmagula's Avatar
Default Re: 2007 Ridgeline codes p0171 & p0174
Did you ever get this resolved? Having the exact same issue with our 2007 Ridgeline. Thanks
Old Jan 4, 2025 | 04:19 PM
Kodyt58's Avatar
I couldn't figure out what the problem was until I took out the motor and took her completely apart. I'm not saying this is your problem and I hope it's not, but after take her apart I found 5 of 6 cylinder walls scratched pretty bad to the point I couldn't hone them. Sorry I could be much help with this, I am now in the market of getting a new motor.
MuhAccord
Aug 11, 2020 05:00 AM
nnneyr
Aug 6, 2020 02:23 PM
vrrodri
Apr 28, 2016 01:57 PM
acidburn2k2
Aug 31, 2015 05:43 PM
drummer1279
Oct 14, 2013 06:20 AM
