Automatic Transmission fluid change out
Old Feb 19, 2024 | 01:11 PM
914lps's Avatar
Default Automatic Transmission fluid change out
Good Day to you All.
I have a 1991 Honda Accord LX 2dr Coupe. Automatic transmission.
The transmission fluid looks OK and smells OK. It is filled to the proper level and having no issues with the transmission.
I have had the car 3 years and only put about 18,000 miles on it.
I'm the second owner
First owner drove it a lot more then I do. So total mileage is around 256,000.
Car runs and drives great. Last oil change I went full synthetic on the engine oil. I thought I would give it a try.
I believe the transmission fluid was last changed about 40,000 miles ago.
I'm thinking about changing it. I have a pump that connects to a drill so I just put a hose down the "dip stick" fill tube and suck out as much as I can get.
Then fill with new fluid. I know some old fluid gets left behind.
What transmission fluid should I use? What about dinosaur oil, or full synthetic, or synthetic blend?
How much does it hold when bone dry?
I know to check fluid level the oil needs to come up to temperature. But what about when draining it?
I can get oil locally from Walmart, AutoZone, or O'Reilly's. Other than a one location Independence store that's it for auto parts around here.
Honda dealer is 120 mile round trip.
As always I thank for your response and help.
Old Feb 21, 2024 | 02:09 PM
ag_ghost's Avatar
10 Year Member
Default Re: Automatic Transmission fluid change out
Owner's manual will specifiy capacities, types and intervals; an online version can be accessed via https://mygarage.honda.com/s/find-honda
juliegrimm
Dec 20, 2022 06:07 AM
earth_grinder
Honda CR-V & Element
Dec 19, 2022 10:41 AM
holmesnmanny
Honda Civic (2006 - 2015)
Jul 14, 2016 05:45 PM
DennisWaller
Feb 29, 2016 02:10 PM
swampjelly
Jan 21, 2013 06:37 AM
