Knock knock! You still alive, Prelude?!
What's up, people!
just showing my budget build prelude.
423whp 380trq turbo setup
wheels 17x9+45 tires Falken azenis 615k+
napa rotors, with endless pads.
comp turbo 6262 t3 turbo with tread stone manifold.
Skunk 2 intake manifold 70mm Blox throttle body
1700 injector dynamics ran on e85 with an aem fuel 320 lph pump oem wire harness
engine: super tech valvetrain with oem cams and cam gears.
Arias pistons 10:1 with eagle rods and golden eagle sleeves
king racing bearings with ACL thrust washers
OEM m2y4 transmission with carbon syncros
DC sports short shifter adapter.
oem suspension bushings, ball joints with CRUX J's racing coilovers
ESP traction bar.
Innovative Mounts
still in works.
With my best friend devin and his crazy prelude build!
Crux j's racing coilovers from japan
Dyno day.
Safter wire hardware for manifold
No more loose nuts. Saftey wire for the win.
Seal for distributor
Distributor seals
Rebuilt and replaced gaskets/seals to stop basic leak.
Disassembled
ESP traction bar.
Innovative Mounts
still in works.
Dyno day.
Distributor seals
Disassembled
KIWI
Mar 16, 2006 03:06 PM
