Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2004 Honda accord 3.0 v6 LX. TPS low input voltage
Old Feb 14, 2024 | 06:35 AM
hellmell's Avatar
Icon4 2004 Honda accord 3.0 v6 LX. TPS low input voltage
I have a check engine light on. I forget the code #, but it is low input voltage to the TPS. The car would go into limp mode (and the TCS and ! lights would come on) after about 20 - 30 min of driving, or sooner if I turned the car on and off a few times. Every time I have measured the input voltage at the sensor it is exactly 5v. Output voltage it 0.5v with the throttle assembly closed and 4.5v open. All exactly what they should be.
I replaced the TPS and the ECM, no change.
I replaced the positive and negative battery cables. The car has not gone into limp mode since, but the check engine light is still on and I am getting the same code.
I don't know what else to do and the car needs inspected soon.
Also I cleaned the throttle assembly but I did not take it off to clean it, it wasn't very dirty. I plan to take it off to clean it more thoroughly, and also clean the EGR valve.
Publicist
Feb 8, 2023 04:26 AM
NovaAccord
Jan 23, 2023 12:34 AM
rmiv1985
Jun 27, 2019 04:10 AM
NoHondaexpert
Jan 2, 2014 09:43 AM
D15Brad
Jun 2, 2003 07:20 PM
