Overcharging issues
Old Feb 3, 2024 | 01:48 PM
ej8.gage's Avatar
Default Overcharging issues
After having some welding done on my 2000 civic ex coupe (with the battery disconnected) my brand new alternator has been overcharging my system up to 18v at 3k rpm my Srs light comes on and I am stumped on what could be causing it I took my alternator in and it tested normal but what could be causing this?
Old Feb 3, 2024 | 06:14 PM
Ehaynes's Avatar
Default Re: Overcharging issues
It seems like the voltage regulator is messing up. It is built in to the alternator, so that would mean that you would need to replace the alternator. I'm not sure if the test could catch that or not. However, I would first check if the wiring is not damaged and all your connections are good. I would try and see if there is anything visually wrong first before jumping to the conclusion but it can hurt your battery if not addressed.
Old Feb 5, 2024 | 12:42 AM
slomofo's Avatar
GDD Member
Luckily your alternator is brand new and you can warranty that bitch out.
Old Feb 5, 2024 | 12:05 PM
ej8.gage's Avatar
orileys turned me away twice and kept telling me it’s still good and told me to run it until it breaks but if I do that it will fry my system
Old Feb 7, 2024 | 01:43 AM
youstolemybeer's Avatar
5 Year Member
have the battery tested to make sure you dont have a dead cell
silverflash0921
Jul 2, 2014 06:32 PM
hondastrtracr
Oct 29, 2007 12:11 PM
blucivicracer
Honda Civic (2001 - 2005)
May 27, 2007 08:36 AM
da9pwnsu
Jan 19, 2007 12:12 PM
SilverSellout
16
Nov 6, 2003 08:47 AM
