Need a wiring pin out diagram for 91 EF Gauge Cluster connector
Old Jan 29, 2024 | 04:01 PM
Blknblue's Avatar
Default Need a wiring pin out diagram for 91 EF Gauge Cluster connector
Desperately need a wiring pin out diagram for this gauge cluster connector in my 91 EF. Pls let me know if anyone can provide one. Tx
Old Apr 29, 2024 | 12:58 PM
Dale_J's Avatar
Default Re: Need a wiring pin out diagram for 91 EF Gauge Cluster connector
I don't recognize that plug as being from an EF. Is that from the ECU or the cluster?
Here is the pin outs for a 90-91 cluster. I didn't make the image, so please don't comment on the "1999" error.
If you are looking for which wire connects to which device, the color codes should be the same for all EF Civics.
Old Apr 29, 2024 | 04:23 PM
95_civic_gsr's Avatar
This is all I could find, Its a little different than the above, but very similar. No Green Connector though:
Old May 12, 2024 | 04:13 PM
I have a JDM SiR Cluster, but it doesn't have a plug like that:
(I don't remember the year, 88-91)
Old May 12, 2024 | 04:21 PM
I agree that looks like the plug for an ECU or something else.
Aren't the plugs for the automatic selector lights on the clusters made in green plastic?
Old May 12, 2024 | 07:11 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
That is harness Connector C711 used for the shift position indicator; cars with automatic transmission.
Old May 13, 2024 | 06:15 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
1 Grn/Yel 2
2 Grn/Blk D4
3 Grn N
4 Grn/Red R
5 Grn/Wht P
6 Grn Park or N input to PGM-FI ECU
7 Yel Fuse No. 1 (10A)
8 Red/Blk Dash/Console Light (+)
10 Grn/Blu D3
11
12 Red Dash/Console Light (-)
13
14 Blk Ground G401
Old May 15, 2024 | 09:25 PM
Thank you Tech8 for answering his question with spot on information. I realize I'm thread jacking, but since its kind of on topic for the same info,
do you have the pin-outs wire colors for the JDM SiR cluster I posted above as well?
DvSiR
Jan 4, 2003 08:29 AM
