Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Headlights
Old Jan 29, 2024 | 03:43 PM
pgagn16's Avatar
Icon3 Headlights
The headlight on the right side no longer works, both bulbs were good both relays are good and both fuses are good., so I am wondering what else would they have in common. The left side is working fine.
Old Feb 3, 2024 | 09:46 AM
Erigon's Avatar
Default Re: Headlights
do you see voltage at the socket pin? and corrosion at the fuse box?
Old Feb 4, 2024 | 06:53 AM
pgagn16's Avatar
Both the high beam and low beam quit at the same time., so I'm thinking that corrosion at the socket was unlikely.. I don't get voltage at the socket, but I can't be sure if my probes are making contact. I don't really want to start working on my wiring this time of the year as I would be doing it outdoor. I'm now wondering if the switch on the column has separate contact for the left and right bulbs. If not them the problem is most likely the wiring,
Old Feb 4, 2024 | 07:05 AM
pgagn16's Avatar
What I am wondering is what does the low beam and high beam have in common ,yet separate from left and right , other than relay, fuses, bulbs and wiring.
1337 Si
Acura TL, RL & ZDX
Feb 17, 2015 09:02 PM
s0biek
Honda Civic (2006 - 2015)
Jun 1, 2012 03:23 PM
96teggynonVtec
Apr 16, 2009 06:45 PM
pcrodrig
Dec 22, 2007 09:59 PM
Kellindal
Oct 21, 2002 11:43 AM
