Honda CR-V & Element 2WD & 4WD Element & CR-V
Car Won't Go Into Gear
Old Jan 29, 2024 | 12:27 PM
catbelly's Avatar
Default Car Won't Go Into Gear
So I was having a problem getting car into gear, if I pumped the clutch it would go, so I assumed Master or Slave cylinder.
I ended up replacing both. I then adjusted clutch pedal and bled system (going through like 2 quarts of brake fluid). The clutch "feels" great - it has good pressure, returns good, etc... but it will not go into gear still. The internet says this is usually a symptom of bleeding but when bleeding I'm really not seeing any bubbles come out anymore. Now even when pumping I can't get into gear (I can change gears fine if car is off). Is there anything else I should look for?
Old Jan 30, 2024 | 04:59 AM
starchland's Avatar
Default Re: Car Won't Go Into Gear
It does sound like air. I would also verify clutch pedal has some free play. Verify slave cylinder movement when clutch is pressed. Check for air leaks. Aftermarket?
Old Jan 30, 2024 | 05:22 AM
catbelly's Avatar
I set the clutch pedal adjustment so the pin can basically go in without moving the pedal at all, not exactly sure how to measure free play here, but clutch feels great
Slave definitely moves after pressed, I see it moving the fork
Yes, both slave and master are aftermarket non-OEM parts
boostedeghatch
29
Jan 3, 2009 12:20 PM
integracura
Apr 18, 2007 11:18 AM
Luchini
Oct 16, 2005 11:15 AM
k20em2
Mar 19, 2005 04:53 PM
