Honda City All versions/generations of the Honda City
Car engine die off intermittent during driving
Old Jan 26, 2024 | 11:24 PM
leong's Avatar
Icon4 Car engine die off intermittent during driving
Good day,
I'm having and issue with my Honda City manufactured in year 2015. The issue begin around August 2023. During the driving the car engine die off intermittently. To be exact, the engine occasionally die off during driving(sometime few time a day), but this not happen everyday. For real exemple, it die off today, and it happen again around 2 day later, sometime even at shorther(within a day) or longer period as for 6 days, this happen on and off. There is no exact time for the engine die off sequence.
The car had been send to Honda 3S center Bintulu and Sibu, Malaysia) to dignoss the said issue, but the result come out was not able to determine the problem, as on last year end, honda 3S center (Sibu, Malaysia) spend a month plus to check and suggest to replace the spark plug, to fix the said issue. However the problem still persist. Thus this become an big issue since the authorized car service center could not find out the said issue.
May i know if any similar issue happen to Honda city owner and any method to solve the said issue? Please help me out due to safety issue. Thank you.
Old Sep 7, 2024 | 03:02 PM
Madfinger's Avatar
Default Re: Car engine die off intermittent during driving
Similar to mine (Honda City 2004).
Changed fuel pump (it was not giving enough pressure)
Changed the Crankshaft Position Sensor.
Changed Air Intake Filter (even though it was still good)
Changed Spark Plugs with better (more expensive ones)
So far it made it run again.
BrianGibson
Honda CR-V & Element
Oct 7, 2025 10:59 AM
amitk75
Honda City
Dec 20, 2017 07:28 PM
c1mead
Oct 26, 2014 09:54 PM
MisterX
Jan 27, 2005 07:59 PM
02EXACCRDCPE5SPD
May 14, 2002 05:43 PM
