1993 Honda Del Sol Si Thread
Old Jan 22, 2024 | 01:24 PM
Javi_14j's Avatar
Icon7 1993 Honda Del Sol Si Thread
So I have 2 1993 Honda Del sol's 1 is an Automatic and the other is a manual, I'm currently in the replacing old parts with new parts faze with my automatic del sol. Just finished replacing Front Engine Fuel Filter, Spark Plugs (NGK), Coolant flush, Coolant Lines changed, New Tires, brake bleed. Some of the things I can name off the top of my head. The next thing I want to do is upgrade the brake fluid lines, I bled the brakes a few weeks ago and the brake pedal has gone soft again, not sure if its the Brake Master Cylinder or the Brake Booster. If there's any tips or products that have worked for you and haven't let you down, feel free to let me know, thanks.
Old Jan 24, 2024 | 01:26 PM
andrey320's Avatar
Default Re: 1993 Honda Del Sol Si Thread
Does your brake fluid leak? If you have no leaks in the lines, replacing them will probably not help....
Old Jan 24, 2024 | 02:28 PM
Javi_14j's Avatar
No leaks with the brake lines nor booster or master cylinder. I'm thinking of changing them all at the same time as i change the brake rotors and pads.
Old Jan 24, 2024 | 02:31 PM
Javi_14j's Avatar
Almost got myself a 1997 but the owner decided on sending it to get junked. Worst thing he could have said.
HairyHarry
12
Jul 9, 2019 11:51 AM
SVOboy
Oct 3, 2005 05:57 PM
rawkus
Dec 19, 2004 09:59 PM
jdmCivic925
Jul 6, 2003 02:06 PM
