98 accord lx crank no start, no immobilizer light at all. Almost 300k miles
Old Jan 22, 2024 | 11:44 AM
Dusty94's Avatar
Default 98 accord lx crank no start, no immobilizer light at all. Almost 300k miles
I got a 98 lx cg5 accord with crank no start and no immobilizer light. The light used to come on. Not anymore. All fuses and relays good, new engine ground wire, replaced fuel pump twice, ign switch, immobilizer, ecu, and spark plugs. Need to recheck for spark. Two scanners couldnt get a response from any system except srs which was pass no fault. Key programmer couldnt get a response to reprogram my key after ign switch was replaced
Also tried moving ign switch harness and immobilizer connecter around incase of spotty connection.
It started one day during when the immobilizer light was just flashing. Shut it off to test it again and After that no more light coming on
There is combustion as i can hear it from the tail pipe
Was driving to work and lost all power, check engine light flashed and cruised to a stop
Any info please help. Thank you
thefirstgen
Jan 27, 2010 05:12 AM
utter02
Aug 7, 2008 11:12 AM
Desiss
Jan 23, 2008 02:32 AM
jjohanson86
Nov 21, 2007 07:22 PM
cb1999nj
Oct 3, 2005 05:28 AM
