F22B1 ODBII to H23A Vtec
Old Jan 21, 2024 | 10:24 PM
WillTheHondaKid's Avatar
Default F22B1 ODBII to H23A Vtec
Hello ladies and gentlemen, first time making a post here. A very original post I’m sure (sarcasm). But I’m having some difficulties figuring out what I should do for my F22B1 to H23A vtec swap. As far as I’ve learned I’ll be reusing most of my F22 sensors and having to wire in a knock sensor and what not. What I’m truly struggling with is most of the guides I’ve read are on the 94 to 95 wiring harnesses. As far as I’ve read that’s the ODBI harnesses and past that is ODBIIa. Which brings me to my question, can I use a F22B1 ODBII Dizzy on the H23? The connector on H22 Dizzys are completely different from the 5 pin I have, unless there is a connector deeper in the harness. And if not how would I go about making a USDM H22 dizzy plug in? Sorry if I need to clarify further I’ve been melting my brain over this for a bit
Old Jan 31, 2024 | 05:15 AM
Luchonesa's Avatar
Default Re: F22B1 ODBII to H23A Vtec
Hello,
New here too, sorry I can't help quite new to cars too. I am about to do a similar swap from H23A non-vtec to H23A vtec.
Which ECU do you recomend for 4th gen lude? P13 or Hondata? Do I have to change from OBD1 to OB2?
Thanks!
Old Jan 31, 2024 | 05:26 AM
Originally Posted by Luchonesa
Hello,
Thanks!
personally for an ECU I’m going to run a P72 with hondata s300 v3 on it, and I figured out what I have to do, you’ll take an H22 dizzy and wire up an external coil, then take the TDC and CKP sensors and a USDM oil pump cover and slap it on, not sure if I need a USDM oil pump, but I would assume not since it just an impeller driven by a belt. Though I’m sure someone will correct me.
and if you’re already ODBI I’m pretty sure that simplifying the wiring, just take your current dizzy and slap it on assuming it has the TDC CKP and CYP sensors in it.
Old Feb 1, 2024 | 07:17 AM
Luchonesa's Avatar
Thanks for the advice. My transmission is Manual so I don't know if P72 is the best way to go for me
Old Feb 1, 2024 | 07:25 AM
assuming you’re going to use a USDM ecu I thought the P72 only came with a 5 speed here in the states
Old Feb 1, 2024 | 07:41 AM
Luchonesa's Avatar
I will go with JDM engine, if you that researched P72 USDM is the way to go I should give it a try
Old Feb 1, 2024 | 07:46 AM
Luchonesa's Avatar
This seems a nice deal https://www.swapshopracing.com/conte...ECU-Combo.html
zebula666ish
Jan 28, 2012 07:06 AM
MJT805
May 4, 2009 03:15 PM
lilo_goki
Dec 19, 2008 08:26 PM
92lude76
Nov 25, 2007 07:39 AM
pdeesSI
Nov 29, 2002 09:30 AM
