Honda CR-V & Element 2WD & 4WD Element & CR-V
Transmission problems!! Help a brotha out
Old Jan 20, 2024 | 03:24 PM
Broke H-CRV's Avatar
Default Transmission problems!! Help a brotha out
2000 Honda CRV AWD
Replacing the transmission on my CRV and everything is identical until some sort of sensor/ harness connection. Newer tranny(Bought from JDM MOTORS)has an 8 pin and the old tranny has a 9 pin. Whatever sensor it is, looks the same and in the same spot.
MAIN QUESTION:Could I simply take the old sensor out and put it in the new tranny? I assume this is a stupid question and I need to return and get the correct one🤷‍♂️ whoever helps it is much appreciated
Old tranny plug
New
Location of whatever the hell im looking at
Old Jan 20, 2024 | 04:23 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Transmission problems!! Help a brotha out
That is the transmission range switch.
Your original USDM connector is 10P. The JDM connector is 8P.
See this other HT thread related to someone else's solution to this issue, which sounds like he used a USDM RD2 CR-V transmission range switch.
https://honda-tech.com/forums/honda-...-swap-3367268/
Luke G.
Aug 22, 2009 09:53 AM
damn_import_culture
Transmission & Drivetrain
Jul 20, 2009 07:27 PM
thesilverfox
Nov 1, 2007 06:49 PM
allanonjj
Jun 11, 2005 06:29 AM
