1991 2d lx Accord won’t start
Old Jan 16, 2024 | 04:22 PM
Natanvzqz's Avatar
Default 1991 2d lx Accord won’t start
Hi i’m looking for help what could be wrong with my accord, I recently did a transmission swap on it and got all the parts back as they should be minus the air box and the spindles because I want to make sure that the axles are engaging before I finish the bottom of the car, but when I turn the key I can hear the it trying to spark but it doesn’t seem to have fuel, I know it has i’m just wondering if maybe there’s a fuel connector I forgot to plug in or anything like that
the car started fine before the whole transmission swap, however now the battery is dead so i’m not sure if there’s anything related to it.
Old Jan 16, 2024 | 09:50 PM
Micro1989lxi's Avatar
Loved
Community Favorite
Default Re: 1991 2d lx Accord won’t start
Well, I guess first charge the battery.
#2 Listen for the fuel pump to turn on when you turn on the key to the run position (just before it cranks over). Door closed and radio off helps)
If the answer is no, there are two main things to look for. There is a 2"x1" silver relay under the dash (driver side up high near outer part of car).
#My 93 has issues at the back of the key switch with the fuel pump not turning on. I have to remove key, jiggle lock with key in it etc to get it to pump fuel.
All of the wiring harness is pretty straight forward on that car, so I doubt that you missed anything important.
Old Jan 17, 2024 | 08:00 PM
Natanvzqz's Avatar
I can hear the fuel pump whirring on, i’m not sure if the relay can be damaged if I never touched anything under there? It was starting fine before with no problems
Old Jan 18, 2024 | 08:25 AM
Natanvzqz's Avatar
I just checked and the starter isn’t engaging it’s only grinding the tip of the fly wheel
Old Jan 18, 2024 | 11:05 AM
Loved
Community Favorite
I am glad to see that have tracked down the problem.
easternmidwest
Sep 12, 2017 05:13 PM
Cabral530
Sep 3, 2012 04:51 AM
frzr
Classic Hondas
Jan 15, 2008 09:57 PM
92civicGA
Sep 1, 2006 11:41 AM
