B20vtec GSR head high idle
Old Jan 15, 2024 | 11:48 AM
mikexluke's Avatar
Default B20vtec GSR head high idle
Hello I recently just swapped a b20z block and a b16 vtec head into my 1993 eg hatchback. The car had been previously b swapped with a b20b block and the same head. It has the same chipped p28 ecu. The only thing I’ve changed is the injectors valve springs and that’s about it. The problem is when it starts it idles at high rpm’s around 3,000-2800. Sometimes the rpm’s bounce too. I diagnosed vacuum leaks and all checks out. The only thing I can think of is the tune. I have the cord to plug into the ecu but will I be able to upload a tune or will I need a new chip? I’m not sure about any of it. Please help I’m very new to this. Thank you in advance-Mike
Old Jan 19, 2024 | 11:41 AM
yogore's Avatar
Default Re: B20vtec GSR head high idle
Was the old block a low compression B20B?
turtlewaxmaster
Aug 6, 2011 08:27 AM
SnailedEG
Sep 15, 2010 03:43 PM
anelliotsaid
Sep 11, 2009 09:31 PM
TylerC
Sep 2, 2005 01:03 PM
Kaotik Individual
Dec 7, 2001 09:18 AM
