Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Sliding door will not open
Old Jan 13, 2024 | 05:29 PM
qwerty_1234's Avatar
Default Sliding door will not open
I have a Stepwgn RG1. A few months ago the seat belt got caught in the door. After that, I could not open the sliding door. I managed to force the seat belt back out of the door jam.
All fuses checked. The sliding door is not automatic.
On the door latch assembly, there are two connectors. One has two wires that go back to the lock actuator. The second connector has from memory 6 wires. When I put the second connector back into the door latch assembly, I could hear the door latch actuator motor working and the door moves in or out a few millimeters.
I have tried some level of physical force but I think the door latch is somewhat stuck. The seat belt is intact so I don't think anything is stuck in there.
Does anyone know how to proceed?
Old Jan 18, 2024 | 02:30 PM
Default Re: Sliding door will not open
Looks like the door latch cable is broken on the latch side.
Does anyone know how to open this sliding door? I have a replacement part so trashing the old part is okay. I bought some wedge pump bags as I thought as the door moved a few mill I could force it open that little bit more. I can get a few more mill from the pump bags. Maybe I could get a coathanger into the latch from there. But not to sure.
Old Feb 5, 2024 | 04:03 PM
Renzo64's Avatar
Hi i have a similar problem tried pushing the door out with my feet. No Luck, I was able to get the door panel out after a struggle. I lubed all moving parts but it appears the cable is stuck in the pulley which is only accessible by removing plastic wall panels in rear. I will try that next.
Old Feb 5, 2024 | 04:06 PM
Renzo64's Avatar
My 07 Odyssey - fuses were all checked and the latch module seems to be working. I plan on cutting the cable and taking it out altogether and just use that door manually.
Mychal71
Mar 20, 2022 01:32 PM
singlecamsaint
16
Mar 5, 2012 04:44 AM
Silent_Destruct
Jan 15, 2007 10:03 PM
'90crxSI
14
Sep 8, 2006 05:26 PM
91 civic
11
Jan 24, 2003 06:34 AM
