Rad fan not turning on
So im having a fan issue the fan isn't turning on car has been up to 196 idle. I have changed everything I am running hondata with a b20v. I have replaced fan switch,relay,thermostat, and even cleaned all the plugs and connectors. After all this the fan doesent seem to turn on so then I replaced my radiator and fan alas still nothing.I have trouble shot everything even with all the new parts that were all oem nothing I even jumped the thermo switch and it works. I do not have ac and I'm wondering if this could be the problem? And yes I've bled the coolant multiple times...
I'm on colorado but it doesent make sense because it gets to 195 and nothing It only gets this hot driving it alot and then idling during driving it gets to operating temp of 185. I believe I may have found he issue my skunk 2 mani for a gsr has an extra line I bought a new housing for it to flow better and maybe even get the thermo switch hot enough to trigger the fans. There should be no blockages except for that as I had it blocked off. I'm linking it to the new housing to help the flow and maybe solve the issue.
