91 Honda Ef wiring problem
Old Jan 3, 2024 | 06:31 AM
Smiley91ef's Avatar
Default 91 Honda Ef wiring problem
Good day Guys
Just wanted to come on here and ask about a few problems I seem to have with my honda its a 91 ef sedan with a d16A7 motor. The main problem is that it doesn't start one night coming home it just died on me and some of the electronics also went and some just worked funny....ever since then I cannot get the car to start. I am young though have no mechanical experience or even expertise this is my first car and I really want to learn how to do stuff myself around the car. Anyways the car cranks for a few cranks and then stops after a while and just cranks.
Any ideas or suggestions of what may be the problem will be very much appreciated Thank you!
Old Jan 11, 2024 | 03:59 PM
frank_el_tanke's Avatar
Default Re: 91 Honda Ef wiring problem
Do you have any Check Engine codes on your ECU? I would start there and make note of what the codes are. I'd also recommend checking the fuses (there are some under the dashboard and under the hood). Make note of which fuses, if any, are blown and replace them. If you do end up replacing blown fuses, see if there is any improvement to your electrical problems (you mention some "work funny").
Old Feb 4, 2024 | 03:01 AM
Tha_JOKE_'s Avatar
sounds like you need to do a MPFI swap. But if you're not wire savvy. You could always pull a wiring harness from a higher up model. Sounds like you have a std ( base model EF chasse) . DPFI can be fixed.
Roche Familia
Classic Hondas
Sep 19, 2016 04:14 AM
KtHaNxBai
Apr 22, 2011 06:37 PM
