How to make right? Driveshaft?
Old Dec 23, 2023 | 06:39 AM
jdmr_neil's Avatar
Default How to make right? Driveshaft?
under the eg2 again today and I can only apologies for the noob posts but it's a long time since i worked on anything but rotaries
The plan today was to refit the arb, bushes and brackets that were missing. I found this and I can see it need to be replaced but I'm not 100% how to go about it.
i do search everytime but sometimes these are quite particular.
Old Dec 23, 2023 | 09:47 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: How to make right? Driveshaft?
That is a called a dynamic damper and is there to reduce NVH (noise, vibration & harshness). They are long discontinued and you will find any aftermarket replacement driveshafts don't have them. If yours is actually loose and able to move, consider simply cutting it off. If it makes you feel better, the Type-R doesn't have these dynamic dampers. Consider it "added lightness".
Old Dec 23, 2023 | 12:10 PM
jdmr_neil's Avatar
Again, thanks for your time to reply and provide the valuable info I need.
I'll look at just cutting this off so I can see what the actual shafts look like underneath.
Thanks again
95DxSi-R2
13
Jul 31, 2007 07:24 PM
B16A3Civic*Eg
Apr 28, 2006 11:12 AM
JDM_rolex
Welding / Fabrication
May 13, 2005 02:54 PM
CRXstress
May 7, 2005 08:16 AM
SuperCivic
17
May 17, 2002 06:13 AM
