Honda CR-V & Element 2WD & 4WD Element & CR-V
Reluctor tooth bent need advice please
Old Dec 13, 2023 | 08:55 PM
ofremen93's Avatar
Icon5 Reluctor tooth bent need advice please
I made a big mistake when I tried to replace my position crank sensor on my 2012 CRV. The sensor got stuck and I tried to remove it by using a drill and sure I removed it alright but
I also appear to have bend one of the reluctor teeth inward. You can see it visibly slightly forward compared to the other teeth.
So now I am facing a dilemma of how to fix.
I took it to two different mechanics.
Both said about the same thing, but I have to decide which of option to go with.
Option # 1 was to drop the pan and gain access to the teeth and straighten that one tooth.
Option #2 is to replace the crankshaft itself....
The first option is a gamble, because if it doesn't work then I'll have to go with option 2 on top of option 1 and the cost will be a lot higher overall.
So I'm just not sure...is it possible to bend a tooth back without breaking it? would it still work that way? or is that crazy to do that?
The mechanic said it was a 50/50 chance option 1 would work.
Old Dec 14, 2023 | 04:30 AM
LordKelvin's Avatar
Default Re: Reluctor tooth bent need advice please
I can't say anything about the feasibility of trying to bend the tooth back but if you're able to replace the sensor (and presumably other stuff too), you can definitely do option 1 yourself. If it's 50/50 then might as well.
Old Dec 14, 2023 | 06:54 AM
Ryanthegreat1's Avatar
It's a simple stamped steel part. Bend it back, easy.
Worst case it breaks off. It's already broken so can't really make it worse.
And if you break it that wheel is a separate part from the crank that bolts on and has a part number. Hell of a job to replace it though.
Old Dec 14, 2023 | 10:32 PM
ofremen93's Avatar
Here's a picture of the bent tooth that the mechanic I took it to sent me.
Old Dec 15, 2023 | 07:16 AM
Bend it back. That's super low risk. Hardly bent at all and well inside of what steel will tolerate.
Old Dec 15, 2023 | 03:42 PM
ofremen93's Avatar
Success!! It worked!!!
I'm so relieved.
Was looking at an engine replacement if it didn't work
fastestridge
Jun 12, 2021 12:57 PM
Brad_and_the_acc
Honda Civic (2001 - 2005)
Jun 16, 2009 01:33 PM
RC000E
Engine Management and Tuning
14
Oct 23, 2008 02:31 PM
96GS-R-Kaden
Nov 17, 2007 07:05 AM
94TealGSR
Jan 16, 2003 09:14 PM
