Help with stereo
Old Dec 9, 2023 | 04:26 PM
romanchamb20's Avatar
Default Help with stereo
Hi guys. I have a issue... When I turn on the ignition my radio turn on normally, but sometimes when I turn on the engine the stereo didn't turn on and it takes some minutos to get back the power. I'm sure is not the Stereo because I changed the old one and the problem stills, and I check the fuse box and the ground cable. I don't know if someone have an idea or can help me with this
Old Dec 9, 2023 | 05:12 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Help with stereo
My first thought would be bad connection on the wire harness. If it's an aftermarket stereo it will most likely have spliced on connector that came with the radio. Same thing goes if the installer made an adapter harness. Either way you could have a bad power or ground splice.
Old Dec 9, 2023 | 06:47 PM
Hi it's an aftermarket stereo. I will check the connections should I focus on some specific cables or every of them?
Old Dec 9, 2023 | 07:10 PM
94eg!'s Avatar
#1 Super Guy
Loved
Like I said, either the power or ground wire. Those are the only two that will prevent it from turning on. Depending on what year you have, the cars wire harness colors will be different.
On the aftermarket side of the harness red should be accessory-power and black should be ground.
racingcrx
Aug 8, 2008 07:50 AM
freeflyinrider
Nov 18, 2007 12:01 PM
blk_eg4
Oct 11, 2007 11:04 PM
dabiddan
Nov 23, 2004 11:08 PM
YoungOne
Nov 24, 2003 04:38 AM
