Swap will crank but no start
Old Dec 4, 2023 | 09:02 AM
Ace3200's Avatar
Default Swap will crank but no start
I swapped a built b18 in my 99 civic ek but It won't start when using a b18 ecu I'm not getting spark and the feul pump is not priming and there is no engine light when in the on pos. I have a hondata ecu for it thats not tuned to the engine yet but has a del sol base map that will give me an eng light in on pos but wont start it either (obviously because its not tuned for it). the b18 ecu ran the engine in a 97 civic without problem. Swapped the same ecu/ hanress with the engine. Can anyone help
Old Dec 4, 2023 | 08:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Swap will crank but no start
The engine harness from a '97 Civic will NOT work in a '99 Civic... the free ECU plug hanging near the ECU under the dash should be an obvious give-away. You need a '99-00 Civic engine harness and you will simply need to modify it to fit your B18 engine.
Old Dec 5, 2023 | 04:11 AM
Ace3200's Avatar
Thanks Im new to this so I didn't know that
Old Dec 5, 2023 | 08:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
No problem. If you need more help, post your questions on this thread.
Alex909x
Jun 29, 2020 10:29 AM
FuNkDrSpOt
Jan 3, 2007 10:04 PM
lude97dude
Jan 21, 2003 08:53 PM
KL
Acura TL, RL & ZDX
Jul 24, 2001 06:36 AM
