TX FA5 Civic Si / K24a2 / FD2r Conversion / 111K miles
Old Dec 3, 2023 | 03:55 PM
rynmkntn's Avatar
Default FA5 Civic Si / K24a2 / FD2r Conversion / 111K miles
2007 Galaxy Grey Civic SI (FD2 OEM conversion)
Clean Title
Chassis and Trans has 111K miles
Engine is 64K mile K24 JDM motor.
$19,000 OBO. Trades open
VIN: 2HGFA55597H711227
Maintenance:
- OEM 50 deg vtec gear with K20a2 oil pump, chain, chain guide, drag cartel lower timing guide
- valve cover gasket
- axle boots
- valve adjustement
- oem tensioner and idler pulley
- transmission fluid
- OEM throw out bearing
- Ktuned CMC and Slave with braided line
-Hubs and bearing all 4 corners
-Front lower ball joints
-ARP extended studs front / oem length studs rear
-Rear rotors and ceramic pads
Engine
- Jdm K24a2 (RBB) sourced from JDM of California
- Hasport Engine Mounts with CRV passenger side mount bracket
- newly replaced OEM 50 deg vtec gear with K20a2 oil pump, chain, chain guide, drag cartel lower timing guide
- K20z3 oilpan with baffle
- newly replaced OEM timing chain and tensioner newly replaced
- Newly OEM replaced tensioner and idler pulley
- Whitfield valve cover with AN bungs with AN line to Whitfield oil catch can/coolant reservoir
- Skunk2 billet oil cap
- Hybrid Racing radiator cap
- Battery Relocation
-Oil catch can and coolant reservoir
Fuel
-Hybrid Racing Fuel Rail
-265lph E85 compatible DW65C Fuel Pump
- DW 600 cc injectors
Intake
- JDM factory J35 throttle body
- Skunk2's Pro Series intake manifold
- P2R Throttle Body Spacer
- Hybrid racing cold air intake with 3 inch velocity stack air filter
Exhaust
- Skunk2 Megapower headers
- Full 3 inch custom exhaust with vibrant resonator and muffler, plus custom Helmholtz resonator to reduce drone.
Transmission
- K20z3 transmission
- Hybrid Racing Shifter Cables, and Bushing
- Spec Clutch Aluminum Flywheel
- Exedy OEM stage 1 clutch
- Throwout bearing replaced
- Acuity 3 way adjustable shifter assembly
Brakes and Suspension
- Monomax RS coilovers with camber plates
- SPC rear camber arms
- Wilwood 6 piston front caliper with slotted rotors
-Aerogenics front balljoint spacer
Interior
- Flash pro with tune from KV tuning
- Pionner double din with navigation
- Amp and subwoofer with custom box
- JDM hazard Light
Exterior
- HFP rear lip
- HFP side skirt
- Backyard Special Rear Spoiler
- Backyard Special front lip
- Backyard Special Grill
- OEM FD2 front bumper
- OEM FD2 headlights with HIDs
- OEM FD2 fenders
- OEM FD1 Trunk
- OEM FD2 Octagon Taillights
- Spoon Side Mirrors,
- Clear Side Markers
Cons:
-Paint fade on both passenger rear doors
-front grill needs to be recleared
-front lip has scratches and scuffs
-rough start on cold mornings/long period of not driving the car due to bigger injectors (CEL comes and goes)
-wiper motor/lever failure (have both replacement parts)
The car was tuned by KV tuning and made 235 hp with 225 torque on a dynopac.
Old Dec 11, 2023 | 06:01 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: FA5 Civic Si / K24a2 / FD2r Conversion / 111K miles
Do you have to lower the engine to change spark plugs?
Old Dec 11, 2023 | 06:05 AM
rynmkntn's Avatar
No, you take off the cowl plastic trim to have space.
USDM DUH
Mid-Atlantic (Sales)
Aug 7, 2013 07:34 AM
850rct9a
Sep 9, 2012 10:44 AM
r1de23
Jul 15, 2009 06:30 PM
r1de23
Jun 30, 2009 07:35 PM
