10mm bolt stripped on thermostat housing
Old Nov 15, 2023 | 04:25 PM
Breighzay's Avatar
Default 10mm bolt stripped on thermostat housing
I have a 2002 honda odyssey and my 10mm bolt stripped on thermostat housing. I can't get a picture of it because it's underneath stuff and I can't see it. But the bolt is stripped and vice grip didn't work its too big and the spot is small barley will fit my hands in there! Help ppl urgent plzzz
Old Nov 15, 2023 | 04:44 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 10mm bolt stripped on thermostat housing
1. Use a 6-point 10mm socket instead of 12-point 10mm socket. 6-point has less chance of rounding the bolt head and more chance of still being able to loosen your rounded bolt.
2. If you can't easily reach it, adding a universal joint will allow you to reach in at different angles.
3. If 6-point 10mm socket doesn't work, then something like a bolt extractor may still work.
Some examples:
https://www.homedepot.com/p/Husky-3-...10MM/202913503
https://www.homedepot.com/p/Husky-1-...V3PC/202934795
Amazon Amazon
tianporn
11
Dec 13, 2014 04:03 PM
Bigrome34
Jun 20, 2010 11:08 AM
JSpekBB4
Jan 22, 2007 10:27 PM
so simple
Apr 10, 2005 11:30 PM
fe519
Jun 19, 2003 05:36 PM
