Blinking Engine Icon On Position 2
Hi all, I’ve got a question for you fellow Honda owners, my engine icon lights up and then flashes while on accessory mode, if I turn it to on, it disappears, it also goes away after a bit in II position, any ideas or help would be very appreciated.
It's in your Owner's Manual, man! It's for the Readiness Code.
"To check if they are set, turn the
ignition switch to the ON (II)
position, without starting the engine.
The malfunction indicator lamp will
come on for 20 seconds. If it then
goes off, the readiness codes are set.
If it blinks five times, the readiness
codes are not set. If possible, do not
take your vehicle for a state
emissions test until the readiness
codes are set."
codes are set."
Awesome, I figured it's nothing bad, I've seen some saying it's a misfire (I figured if the engine was on and had the flashing it'd make sense), yeah I also seen it may be the emissions system reset(which here in florida we don't do smog or emissions testing).
Thanks friends! 😊
Thanks friends! 😊
kyle45
11
Aug 30, 2007 06:43 PM
