89 EF Shock tower plug
Old Nov 8, 2023 | 05:19 AM
Ef地's Avatar
Default 89 EF Shock tower plug
hello all, i致e been doing an mpfi conversion to my 89 ef with a b18b1 swap.. the conversion and swap is done for the most part, most of the driver side shock tower plug is chopped by previous owner.. there are two wires that aren稚 chopped coming from the 14 pin plug.. can someone tell me where all the other wires go? thank you
Old Nov 8, 2023 | 09:44 AM
Ef地's Avatar
Default Re: 89 EF Shock tower plug
bump
Old Nov 8, 2023 | 11:09 AM
jlicrx's Avatar
Old Nov 8, 2023 | 01:29 PM
Ef地's Avatar
i知 mostly confused about where the wires go exactly tho, what connectors do they go to?
Old Nov 11, 2023 | 06:57 AM
jlicrx's Avatar
what engine harness are you using?
are you also converting from OBD0 to OBD1?
what ECU are you using?
Old Nov 11, 2023 | 10:04 AM
Ef地's Avatar
using the stock ef engine harness, going to obd1, p75 ecu. i致e wired up the eacv since..
Old Dec 12, 2023 | 03:22 PM
Arodriguez562's Avatar
Look at the display and look at your connector which numbers are you talking about for the 2 wires
Datunnerkid
Dec 5, 2010 07:10 AM
xef_twinx
May 17, 2010 04:43 PM
dertymatt
Dec 20, 2007 03:24 PM
slowslow
Mar 22, 2007 02:56 PM
