00 honda accord transmission
Old Nov 3, 2023 | 09:11 PM
asoard's Avatar
Default 00 honda accord transmission
Ok I have a 2000 Honda accord, it’s been a good car until I let a friend borrow it. The transmission started shifting rough. It finally popped the check engine like with a blinking d4. I got the codes: P0780 Shift Malfunction, P0700 Transmission control system, P0705 Transmission Range Sensor (circuit malfunction 2-posi, P0706 Transmission range Sensor Circuit Range/Performance (no-posi). I replaced the transmission speed sensor. Now, when you’re at a complete stop, 1st head starts super slow and revs high then once it rough shifts to 2nd, it drives just fine. I need help I did read the code after installing and it doing it again and now all i get is a P0780 shift malfunction.
Old Nov 4, 2023 | 02:27 PM
Aradin's Avatar
Premium Member
Default Re: 00 honda accord transmission
Check and clean the solenoid screens. Change the fluid. If neither of those helps then your transmission is on it's way out. They are notorious for failure in that generation.
Old Nov 4, 2023 | 03:40 PM
02AccordV6's Avatar
Where are the solenoid screens? What has to be done to get to them?
johnny225
Feb 10, 2021 11:09 AM
Joseph Burrough
May 7, 2017 05:29 AM
black accord
Mar 11, 2014 02:18 PM
eman96
Aug 8, 2013 12:34 PM
jw 1
Jun 25, 2013 04:17 PM
