Praying for help on a 1997 Accord 2.2 VTEC
Old Oct 31, 2023 | 03:35 PM
crscamaro's Avatar
Default Praying for help on a 1997 Accord 2.2 VTEC
Sorry that this is my first post, but I am searching for assistance and came across your forum. I have done many searches and found various answers; what I honestly expected as I'm sure there are plenty of causes for my problem. Issue is on my son's car. As he left school yesterday, the car went about a quarter of a mile then stalled out. He was able to start it back up, only making it a couple hundred more feet before it shut down again. When I made it to him, I attempted to start and was getting crank but no start. It did actually start, after many attempts, and I was able to feather the gas to keep it running about 15 seconds. It died again and will only randomly try to fire off; but the car will not start. Please note, any time it attempt to try to actually fire, it's only 1-2 seconds and only occurs few and far between attempts.
What I have checked based on searches:
1. No spark. Now I don't have any fancy tool to check this, but I pulled each plug and grounded; having my son attempt starting. Only 1 plug showed a tiny spark, but that was it......and it was like one little spark then stopped immediately.
2. I can hear the fuel pump turn on and assume fuel is good as each plug showed clear sign of fuel delivery from the attempts.
3. No CEL. My first thought would be crank/cam position sensor; but wouldn't I get a CEL??
4. Pulled dist cap; all looks great. Had son turn over to ensure rotor turned as it should; no issues.
Any thoughts? I purchased this as a 1st car for my son and it only has 150kish miles currently. I appreciate any assistance!
Old Oct 31, 2023 | 05:37 PM
nicolaselias's Avatar
Loved
Community Favorite
Default Re: Praying for help on a 1997 Accord 2.2 VTEC
My first thought honestly is ECU or igniter module (in the distributor)
Before you get to that though, make sure the engine is properly grounded. Just for a trial, connect a jumper lead from the engine block to the negative on the battery (or the body itself) and then try starting and see if you get spark. Free to check
Old Nov 1, 2023 | 09:43 AM
angrysmileyface's Avatar
Are you getting any codes when you hook up a code reader? Do you even get the CEL during bulb check? Also the ecu is hidden under a plate in the passenger footwell under the firewall carpet. If you take it out and open it, are there exploded capacitors or things smell like rotting fish?
Old Nov 3, 2023 | 09:48 AM
Apollo11's Avatar
If I were in your position, I'd get my hands on an inexpensive obd2 reader that has live data and start there. First thing that came to mind for me would be timing, or timing related (sensor, timing belt jumped a tooth, something like that). It's hard to say without the data or trouble code.
Old Nov 27, 2023 | 01:48 PM
Swolf's Avatar
Crscamaro,
Did you resolve the issue? If so, what was it? I have a similar issue.
Thanks,
John
Old Dec 6, 2023 | 11:02 AM
nus_dogg's Avatar
Doesn't hurt to check, but one time when I did my headgasket, I forgot to tighten down the engine harness ground that bolts up to the driverside intake manifold. It was loosely finger tight. There was no spark whatsoever. But after a few days, my buddy found that we never tighten down the ground wire on the intake mani. So if I was you, it doesn't hurt to remove it and make sure it's free of corrosions.
Old Dec 6, 2023 | 12:56 PM
Loved
Community Favorite
S A M E problem nus. After doing my HG it wouldnt spark either and i bought another distributor, and still no spark. Was that one damn ground hahah
Old Dec 6, 2023 | 01:31 PM
nus_dogg's Avatar
LOL. Yeap, something small and simple that we tend to overlook. But we learn as we go, and that damn ground, I will never forget to leave it loose ever again. I always made sure to to tighten it down now. Never did it again. LOL.
emfman
Oct 19, 2014 10:37 AM
1965fairlane
Oct 10, 2013 09:58 PM
Dynasty21
Oct 18, 2012 11:41 PM
jdmmilf88
Jul 15, 2012 12:15 PM
LSVTECTEG18
May 16, 2008 09:37 PM
