Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
what can be used from TSX in EG swap
Old Oct 25, 2023 | 06:20 AM
ThennyDlux's Avatar
Default what can be used from TSX in EG swap
Hello, I wasn't sure where to post this. I have a 2004 TSX base and a 1995 DX hatch the plan is to swap the K24A2 from the TSX into the EG and wanted to start a thread on what all parts can be used from the TSX in the swap. I had heard the shifter cables and shift could be used. having the whole TSX and not just the engine and trans I didn't know if there were some extras i could use from the TSX.
Old Oct 25, 2023 | 02:10 PM
Ryanthegreat1's Avatar
Default Re: what can be used from TSX in EG swap
Are you planning to go to a throttle cable and RSX ECU?
You could stay drive by wire and use the TSX ECU. Bit more work for sure but it can be done.
DX? So small knuckles? The TSX brakes are a nice big brake option on the bigger EX/SI knuckles and a 5 lug conversion.
Eg9502
Sep 7, 2014 11:30 PM
hondastreet
Mar 5, 2008 12:36 PM
jdmitrhatch
May 20, 2004 07:46 AM
