help with ac ive hit a wall
Old Oct 17, 2023 | 02:19 PM
robot4uu4u's Avatar
Icon4 help with ac ive hit a wall
I've verified the relay is good for ac compressor and when i press the ac button the condensor fan turns on and the pressure switch is good and there is continuity between the 2 points on the sensor i tried grounding p2 wire on the pressure sensor nothing if i jump the realy i get the cold ac
Old Oct 17, 2023 | 04:11 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: help with ac ive hit a wall
Try sending 12V directly to the compressor clutch - does it lock up? If not, you probably have a bad clutch. It's easier to just replace the entire compressor than it is to replace just the compressor clutch.
Old Oct 17, 2023 | 04:15 PM
robot4uu4u's Avatar
I can get the compressor to work by jumping the relay the ac blows cold and the relay is good
when I jump the wire on the ac presure switch to a free air ground the fan kicks on but no clutch
Mp03em2
Honda Civic (2001 - 2005)
Sep 9, 2023 08:53 AM
Single-Cam
16
Feb 10, 2016 07:23 PM
KGNickl
May 1, 2008 01:59 PM
Civic Racer X 7
Aug 8, 2007 05:15 PM
