Honda CR-V & Element 2WD & 4WD Element & CR-V
'01 CRV, cold start rough idle. can stall.
Old Oct 11, 2023 | 06:59 AM
cardonebroke's Avatar
Icon2 '01 CRV, cold start rough idle. can stall.
2001 CRV, 4wd.
Run's perfectly when air temp is above 50F - 60F
Morning rough start, rougher idle. Engine shakes. Pressing the accelerator pedal doesn't change RPM. RPM very low. Sometimes stalls out.
Spark plugs all covered in carbon. Looks like some oil getting up into ignition coils.
Code: P0420; some O2 issue. Put in new up/down stream sensors.
Tried turning the key several times to just allow the fuel pump to get pressure in line. No real difference.
Clean throttle body & IAC. No difference.
Previous owner says they did valve lash recently.
New distributor. Previous owner says new plugs & wires.
When I go to start the car when air temp is warmer (and it starts up and runs good), seems like the starting takes a second or two longer, like fuel needs to get somewhere. Not sure.
Thoughts?
Old Oct 12, 2023 | 07:57 AM
starchland's Avatar
Default Re: '01 CRV, cold start rough idle. can stall.
Consuming oil/coolant?
verify valve lash
tradosaurus
Jul 12, 2021 04:29 AM
NorcalS2K
Honda S2000
Nov 6, 2020 12:55 PM
sikvic123
Engine Management and Tuning
Nov 9, 2019 01:32 PM
murtceps
Feb 26, 2010 02:41 PM
jose310
Jan 6, 2009 04:19 PM
