So i just bought a 1989 civic EF that has been swapped with a b18b1 and p75 obd1 ecu.. the engine harness hadn稚 been finished yet and i知 a complete newbie to this.. i wired the injectors, and cleaned it up a bit. the part i知 stuck on is the wires that are left over, wires that previous owner chopped. the wires are red/white (coolant temp sensor),green/white (TPS), red/blue(TPS),white shielded with green(MAP), yellow/green(MAP) coming from the passenger side plugs and black/green(main relay) coming from drivers side plug. i just don稚 understand what i知 supposed to do with these wires. do i find plugs for them? am i missing more wires? here痴 the harness
