D15B7 crank no start
Old Oct 5, 2023 | 03:21 PM
95Honda-D15B7's Avatar
Icon4 D15B7 crank no start
Hello all,
beating my head against the wall here,
this vehicle was driving and stalled a mile down the road, wouldn't restart.
Timing belt is NOT broken, and has NOT been replaced recently.
NO work was done before this incident.
I Have:
Spark, fuel, compression....
if i pull the plugs and set them above the cylinders all four will shoot flames out of the holes.
if i spray ether down into the cylinders or intake and try to start, turns over but, it won't even kick.
compression is:
1:~140psi,
2:~135psi,
3:~150psi,
4:~150psi
key on, fuel pump primes (~2 seconds), raw fuel smell at the tail pipe, and vacuum at the intake when turning over.
no check engine light...
no codes when OBD is shorted...
Any thoughts?
Old Oct 7, 2023 | 06:28 AM
Icon6 Re: D15B7 crank no start
Solved, Ignition control module failed "Weak spark"
Senditdude
Honda Civic (2001 - 2005)
11
Jun 5, 2024 01:45 AM
Joe Leoffler
Jun 25, 2019 02:55 PM
Kasper21
Jun 5, 2015 06:29 AM
Maldonw
Dec 19, 2014 03:41 AM
erniecombs
Sep 26, 2007 06:21 AM
