b18c crank but no start
Old Oct 4, 2023 | 04:31 PM
lemong's Avatar
Default b18c crank but no start
the other day i was driving home and i noticed the rpm gauge bouncing from 9k-2k pretty much all over the place, it then stalled and wouldn’t start, fuel pump is priming and engine is cranking i was wondering if anyone has had this issue and could point me in the right direction
Old Oct 4, 2023 | 08:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: b18c crank but no start
It is likely the ICM... and I suggest you replace the coil at the same time.
Old Oct 4, 2023 | 11:27 PM
lemong's Avatar
i have a distributor rotor and new a new ignition coil and coil leads aswell as spark plugs
poptik
Nov 25, 2010 07:11 AM
