Ignition timing Connector
Old Sep 26, 2023 | 02:34 PM
Falcie39's Avatar
Default Ignition timing Connector
Hi guys i have a 88 CRX SI with a b18b1 and p75 ecu. The problem i am running into is that i don't have the 2 pin connector that would normally be jumped to set ignition timing and viewing of DTC. So i just wanted to make sure that before i start wiring in a plug that i do it right. So to wire it in i would run a 2 pin plug, one wire to pin 20 on connector B, and the second wire to ground, right? Thank you in advance for the help!
Ef4doorwagon
13
May 14, 2014 05:58 PM
Donkey85
13
Aug 3, 2011 12:08 PM
rasinhell
May 24, 2005 06:32 AM
type Gendy
May 18, 2003 02:53 PM
