93 accord radiator fan doesn’t work when car is on.
Old Sep 25, 2023 | 09:05 PM
Ltchy_Bebis's Avatar
Default 93 accord radiator fan doesn’t work when car is on.
I have a 1993 Honda accord 10th anniversary edition and the radiator fan won’t come on when the car is running but the moment the car is off it turns immediately on.
My temp gauge works just fine, and I’ve replaced temp sensors and thermostat, relay, and fuses but the problem persists.
Not sure where to go any direction and help is greatly appreciated. Thanks in advance.
Old Sep 26, 2023 | 07:47 AM
ag_ghost's Avatar
10 Year Member
Default Re: 93 accord radiator fan doesn’t work when car is on.
Which fan? FWIW, have you looked at the "B" fan switch (at the water outlet - not the thermostat)? I forget at the moment which fan was running when the key was extracted from the ignition (driver side I think), and here's a thread on this site with more background.
Pulling the connector at this switch stopped the fan, though I was careful to reconnect before I drove the car.
An OEM part number appears available (37773-PT3-505), but at 5x the cost I took a chance and tried the Beck/Arnley 2011608 with success.
Last edited by ag_ghost; Sep 26, 2023 at 08:00 AM. Reason: found thread on this site for reference
Old Sep 26, 2023 | 09:15 AM
I would assume switch “B” works fine as the fan turns on after the car has been shut off. The car will start to over heat whenever I’m stopped at a red light or such. Also it is passenger side fan that is not working.
katsbobo
Aug 3, 2008 03:15 PM
B16Power
Mar 28, 2005 11:32 PM
ocdcivic
Mar 10, 2005 04:50 PM
