205/50/15 vs. 195/55/15?
Old Nov 18, 2002 | 01:57 PM
BeerMan's Avatar
Default 205/50/15 vs. 195/55/15?
I did a search and just came up more confused.
I have a 92 Si at stock height. I am looking to get Kuhmo 712's. Will I get wheel rub with 205's. What if I have a couple extra people in the car?
Advice? Recommendations?
Old Nov 18, 2002 | 01:59 PM
Mike P.'s Avatar
25 Year Member
Default Re: 205/50/15 vs. 195/55/15? (BeerMan)
There should be no problem with running the 205s. As long as you have a proper wheel for it. (6" or wider)
B_CRUZ!'s Avatar
i have 205/50-15 Azenis with a 2 finger gap all around and i rub in the rear. I have a 40mm offset. I suggest 205/50's in the front and 195/55-15's in the rear.
Also Azenis are actually wider than what they say on the sidewall.
just my $0.02
Old Nov 18, 2002 | 02:13 PM
BeerMan's Avatar
Default Re: 205/50/15 vs. 195/55/15? (B_Cruz)
what about the kuhmo's, if azenis rub and are wider than they say, will 205 kuhmo's rub?
Please help, I can't seem to make up my mind on this one.
Old Nov 18, 2002 | 02:26 PM
B_CRUZ!'s Avatar
Default 205 Kuhmo users chime in*
Help a brotha out!
Old Nov 18, 2002 | 02:27 PM
MIZIKETSK's Avatar
look and the rear wheel well. There is a little metal tab where ther bumper and rear quarter panel screw together to hold it, just bend that tab inward and that will get rid of the rubbing. I've done it and done it fir everyone I know who had that problem and it worked.
Old Nov 18, 2002 | 02:35 PM
BeerMan's Avatar
Default Re: 205/50/15 vs. 195/55/15? (MIZIKETSK)
No ****? That's good to know.
Anyone else have an opinion?
Old Nov 18, 2002 | 02:41 PM
sammysnakes's Avatar
205 kumhos measure correct, 205 azenis are actually 219.
Old Nov 18, 2002 | 02:44 PM
dwnthehatch's Avatar
Default Re: 205/50/15 vs. 195/55/15? (chainsaw)
I had 205/50/15 kuhmos on 15x7" slipstreams with 40mm offset on my ek with an approx. 2.75" drop and never rubbed.
Old Nov 18, 2002 | 02:48 PM
BeerMan's Avatar
Default Re: 205/50/15 vs. 195/55/15? (dwnthehatch)
Thats what I like to hear. But what about an EG?
Old Nov 18, 2002 | 03:53 PM
b00stn's Avatar
205/50/15 S-03s and no rubbing at all (H&R sport springs). Here is a pic:
They have a sidewall the is a few mm shorter than the 55 series, but they are about 3/4 of an inch wider. Give you a little curb protection also.
Old Nov 18, 2002 | 04:11 PM
JdmVetteEater
Guest
Posts: n/a
I have a 94 cx, i have 215/40/16 with the car dropped 2.5 inches.... it never rubs.. and running 215's i got a 1.96 60ft time....
Old Nov 18, 2002 | 04:38 PM
VTEC
Guest
Posts: n/a
Default Re: 205/50/15 vs. 195/55/15? (JdmVetteEater)
195/50-15 maintains a rolling circumference close to stock...
Old Nov 18, 2002 | 04:41 PM
weezerdotc0m's Avatar
Default Re: 205/50/15 vs. 195/55/15? (VTEC)
I have 205/50/15 Kuhmo with a 1 1/2 finger gap in front and 1 finger gap in the back and i have no problems...hope this helps...
edit: then again, i have an integra...
[Modified by weezerdotc0m, 5:42 PM 11/18/2002]
Old Nov 18, 2002 | 04:52 PM
Todd00's Avatar
I said I don't want a title!
Either get 205/50 or 195/50, 195/55 will kill the acceleration since they are taller than both of those.
None will rub.
Old Nov 18, 2002 | 05:53 PM
TrboInteg's Avatar
I have my eg lowered w/skunkworks coilovers and I have a set of Falken ZE502 205/50/15 on a set of SI wheels and I have know problem what so ever. Depending on where you live in MD, we could meet up so you can see for yourself.
Old Nov 18, 2002 | 05:54 PM
haloseven's Avatar
Default Re: 205 Kuhmo users chime in* (B_Cruz)
i use 712s in 205 format with ITR springs (slightly lowered) and me and 2 friends go fine w/o scraping...
Old Nov 18, 2002 | 06:00 PM
gsrvx's Avatar
New User
how the hell do you get 1.96 on nittos?
Old Nov 18, 2002 | 06:03 PM
IM ALL BOB's Avatar
Default Re: 205/50/15 vs. 195/55/15? (RK)
maybe he has DRs ?
Old Nov 18, 2002 | 06:19 PM
bretx0r's Avatar
195/55-15 = smaller contact patch
205/50-15 = bigger contact patch
thats about the only difference, the sidewall size is about the same.
Old Nov 18, 2002 | 06:27 PM
gsrvx's Avatar
New User
Default Re: 205/50/15 vs. 195/55/15? (IM ALL BOB)
maybe he has DRs ?
I'm assuming he didn't. Looking at his sig...it says Nitto 450's..the drs are NT555Rs right?
-Rod
Old Nov 18, 2002 | 06:42 PM
IM ALL BOB's Avatar
yup.. maybe he has magic NT450S =P
Old Nov 18, 2002 | 07:25 PM
b00stn's Avatar
Default Re: 205/50/15 vs. 195/55/15? (Todd00)
None will rub.
??? what are you talking about? 195/55/15 is what is on there from the factory. 205/50/15 is only a few mm short in overall diameter and would make amount of noticeable difference in acceleration.
Old Nov 18, 2002 | 08:18 PM
JdmVetteEater
Guest
Posts: n/a
Default Re: 205/50/15 vs. 195/55/15? (b00stn)
no i am not making that up i have nitto 450's ..... 215/40/16.... I would be more then happy to post the time slip..... and i did cut a 1.96 60ft. time... wasnt magic it is a fact..... i know guys here that cut low 1.8 60ft times and it is all in your suspension setup.....late
Old Nov 18, 2002 | 08:22 PM
gsrvx's Avatar
New User
Hey..I did not say you made it up...just wondering how you did it. What's ur suspension setup like? How did you launch?
-Rod
