97 honda odyssey HELP!
I have a 97 honda odyssey, little over 100,000 miles. Had coolant leaks never overheated was just putting coolant in it as needed. Leak got worse and began overheating quickly, so we repaired the leak and also replaced the thermostat sensor(or so i believe) . No more leaking Still overheating, also the fans are not coming on until after I turn van off and just one of the two....ANY IDEAS OR WANT TO BUY IT 😂
After coolant loss and refill you must bleed off air from the bleeder fitting on the top rear passenger side near the firewall, it takes a 12mm flat wrench, similar to a brake bleeder. Pop it open and it should spit bubbles and then a constant stream. If the coolant switch for the fans is in an air bubble it can't know the coolant temp. There are two coolant sensors, one is a switch for the fans and one is a sender for the gauge.
Evangelina
Aug 25, 2014 09:09 AM
