Hi, i need some help thanks 2008 crv 2.4 Cranks,but dont start All relays and fuses are in good condition All grounds are at 0.0 omhs The green key ligth never go on when i switch the inginiton. Dont flash, no nothing of green key The PRND21 ligths on dash dont go on (dont matters the position of the shift ****) All other ligths in the dash are fine Scanner cant communicate with pcm All the pins of the pcm conectors have 12v and grounds where needed
Even the imobilizer have the correct grounds and 12v supply in correct order The same for the obd conector All the relays where tested ....all the fuses Are fine, I try with a diferent pcm and is the same no green light
no communication whit scanner
I test the original pcm in another crv and the green light start blinking and the PRND21 ligths on dash got power , and i was abble to read the pcm, that make me think pcm is fine Somebody maby have clue thanks Forgive my bad english,
Hi, did you solve the problem? Got similiar but its cold weather related. No green key after several attempts green key starting to blink i gets really bad when cold and no obd co.munication till the firs immo green key blink
