air bag or coil over suspension for an Accord?
I need a full rebuild on the suspension of my 2015 4-door Accord "Sport" with I4M6. I occasionally run heavy or tow a light ~1500lb trailer so, adjustable suspension seems preferable.
I have run Firestone air bags in the past on my pickup with awesome results. I obviously I don't need anything that heavy. However, the air bag suspension concept seems to be a solid one for this application. I see a lot of CUSTOM SLAMMED CIVIC applications from my Google searches but, nothing for the Accord.
Then there is the coil over option which is typically used for flush fits and dealing with larger low profile tires. I am running 18X7.5 Enkei RPF1 18X7.5 wheels with 225/50R18 tires so, the wheel well is pretty full. Coil overs would seem to require manual adjustments for varying loads so, that seems less desirable.
What are my better options for uprated suspension that can be load adjusted easily?
TIA,
Sid
- Coil Overs
- Air Bag suspension
- Other???
TIA,
Sid
