D16 rebuild - scrapping noise when hand turning crankshaft
Old Sep 18, 2023 | 08:45 AM
Guzo98's Avatar
Default D16 rebuild - scrapping noise when hand turning crankshaft
Rebuilding a 1993 D16 engine.
after install pistons and crankshaft i test turned the crankshaft counter clockwise
get a slight scraping sound on 1st and 3rd quarter turns with a little resistance.
2nd and 4th quarter turns are smooth and silent.
any ideas as to cause?
Old Sep 18, 2023 | 12:43 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: D16 rebuild - scrapping noise when hand turning crankshaft
did you clean the internal parts before installation? Noise is likely the motor building compression.
Old Sep 18, 2023 | 01:39 PM
Guzo98's Avatar
thanks for the reply. Yes new pistons and rings, oversized and bore honed to match by a shop. Rings within spec. Oiled before install
all cleaned too
no head on block when I tested crankshaft turnover
its strange it only happens in first and 3rd quarters of counterclockwise rotation
I put a torque wrench on it and 1st & 3rd quarter turns need 20 ft lb
2nd & 4th quarter turns are 5 ft lb
new thrust washers, pistons, rings, main and rod bearings
assembly lube on all parts
pistons and rings oiled up
h0ndaSi
Honda Civic (2006 - 2015)
13
Oct 30, 2012 04:56 PM
1clean01
Honda Civic (2001 - 2005)
May 2, 2012 08:11 PM
jeffb16
Oct 6, 2004 05:00 AM
